Other Parts Discussed in Thread: TAS5760M
We would like to know the recommended procedure of the register access using I2C for TAS5760M.
Should we set values to each register after we apply power supply and the clocks(MCLK, SCLK, LRCK) to the device?
Or if we apply power supply, can we set values to each register?
We would like to know that for example, if we apply power supply or clocks are input, it is possible to set values of each register after 1ms.
If there is the timing constraint for this device as stated above, could you please tell us about it?
In addition, if we set values to each register after we set SPK_SD pin to low, should we have a wait time?
If we should have it, could you please tell us it in detail?
Kato
