Other Parts Discussed in Thread: PCM1803A
It appears that the PCM1803A analog input has an internal pullup resistance to the reference voltage. This was observed in a circuit having a resistor in series with the input which caused a low voltage before the series resistor to increase to a higher voltage at the ADC input. Is this indeed how the ADC is wired internally? If so, how much does the internal resistance vary with temperature and from device to device?
