TAS5538 Sample Rate Dependent Parameters
Other Parts Discussed in Thread: TAS5538
If we use the automatic bank switching, we believe that the sample rate dependent parameters in the TAS5538 require different coefficients and data depending on the sample rate as it is mentioned on page 50 of TAS5538 data sheet, their parameters are biquad, loudness , drc and tone coefficient values.
Thus, if we use the biquad filter with 44.1kHz to 96kHz as the sampling rate, the biquad coefficient values which are depended on each sampling rate must be set.
Is our recognition correct?
Kato
