ENABLE pin on LME49724
Hi all, first post here and not sure if in the right forum, but here goes.
I am designing yet another microphone preamp and I am wondering how to effectively use the enable pin.
In the architecture I am implementing, saving a bit of power is not an issue, but I wonder if I can use the enable pin as sort of a 'MUTE' function.
What is the behaviour of the amp while disabled if there is a normal amplitude signal at the input?
When the amp is disabled, what kind of input protection should I consider?
Thanks, Luc
  • Hi, Luc,
    Welcome! Glad you get to work on your passion!
    I don't have experience with this device, but I would assume based on my experience with other devices that the inputs will clamp any input signal to a diode drop above ground due to the esd cell.
    We have a standard Evm for op amps that you should be able to drop this on and see if it will fit your needs. Let me know if you can't find it. I think it costs $5 or something like that.
    D2
