CC8531 with CC2592
Genius 3475 points
Other Parts Discussed in Thread: CC8531, CC2591, CC2592, CC2590, CC2538
HI
I saw a forum thread on some challenges of using CC8531 wth CC2591
http://e2e.ti.com/support/wireless_connectivity/f/382/t/312614.aspx
Would like to check if it is possible to match CC8531 with CC2592?
What are the estimated improvement in terms of output power and sensitivity for above combination?
I saw this numbers on the CC8531 and CC2590 webpage
  • Seamless Support for CC2590 Range Extender (+11 dBm Output Power,
    –87 dBm Sensitivity)
Hope CC8531 with CC2592 can give significant better result if they can work together.
Pls advise
Ivan
  • Hi Ivan,
    The CC2592 would give an output power ~20 dBm. As a reference you could use the CC2538-CC2592 reference design. The CC2538 and the CC85xx are very similar when it comes to the RF part.
    This application note gives a lot of information about this combination:
    http://www.ti.com/lit/an/swra447/swra447.pdf
    Johan
