PCM3168 Differrential input - Differential output buffers
Other Parts Discussed in Thread: PCM3168, PCM4204, PCM4202
Hi: Im doing a desing with the PCM3168... I need a buffer for a differential input signal, and with differential Output...
In the PCM3168 datasheet i only found Diff input - Single ended Output... I've worked with PCM4204 before and i wanted to ask if i can use the same buffers explained in the datasheet for this device, using VCOMAD for the refference for the buffer...
Sorry for my english
