Other Parts Discussed in Thread: SRC4392
I am using the SRC4392. I am trying to read the DIR UNLOCK status using I2C at register Page 0 0x14. This bit appears to always be a zero for me showing the AES3 decoder and PLL2 are locked even with no AES3 signal applied. Also this bit does not match the external LOCK_N pin of the device which does toggle as I apply or remove an AES3 signal. I have made sure I unmasked all the Page 0 0x14 status bits by setting all bits of Page 0 0x16 to ones. Furthermore, I can read back the VBIT value properly which is also in register Page 0 0x14. Can someone help determine why this UNLOCK bit does not match the LOCK_N pin?
Thank you,
Erik
