Missing info in the datasheet of LME49810
Input impedance
Input bias offset current
Can you give any hint about these values?
Input impedance
The input bias current is stated to be 200nA max and 100nA typical. This tells me that the input structure is bipolar. This also tells me that the input bias current offset will be on the order of nA; most likely in the 10's of nA.
As as SWAG, the input impedance will be close to 100kΩ||5pF.
-Ken
You mean nano amps, I'll suppose?
Anyway, thanks for the info. Maybe you should add this info into the data sheet?
