No audio or errors TAS5727
Other Parts Discussed in Thread: TAS5727
Hi
I am having problems getting audio from TAS5727.
SDin = audio data
LRclock = 44.1 KHZ
Sclk = 2.1 Mhz
Sclk linked to Mclk
I send over I2c
0x1B,0x00 Trim
0x00,0x60 Control 1, 44.1/48-kHz sample rate, MCLK frequency = 64 × fS
0x04,0x05 I2S Default
0x05,0x02 Control 2, Fault pin = output
0x07,0x00,0x00 Master Volume
I read 0x02 error reg = 0x00, no error
The TAS5727 is outputting a square wave, The fault pin is showing no fault,
Please help
  • Hello John,
    Can you please describe where are you measuring the output signal?, perhaps the square wave you mention is the PWM output of the device. As a Class D amplifier, this device requires a LC filter before the speaker.
    About the clock rates, I recommend you to take a look to this wiki page, there is an explanation of the possible clock combinations for the TAS57xx devices. 2.1MHz is not recommended for MCLK at 44.1KHz sample rate.
      -Diego Meléndez López
       Audio Applications Engineer
