TAS5630B_SE
Other Parts Discussed in Thread: TAS5630B, TAS5630
I have a question of TAS5630B SE circuit.
Please support your comment below list.
>Attached file :
->schematic : 4ch_SE
->freq1 : SE,10~100KHz, -3dB point is not good frequency response.
>Question :
->Is this right origin TAS5630B,SE frequency response ?
->If graph is right, please send me available improving method?
->Is TAS5630B specification available  BTL(2ohm) ? or SE(1ohm)?
best regards,
Eddy
tas5630_SE.zip
  • Hi Eddy,
    Q1. freq1 : SE,10~100KHz, -3dB point is not good frequency response.
    A1 -  I think you mean 10W to 100W.  Will you tell me what is not good about it specifically?
    Q2. If graph is right, please send me available improving method?
    A2 - What is the specific improvement parameter target that the customer is looking for?  And will the customer be willing to put more components on the system?
    Q3.  Is TAS5630B specification available  BTL(2ohm) ? or SE(1ohm)?
    A3 - TAS5630B supports 4 Ohm minimum in BTL and 2 ohm minimum in SE.
    Tuan
