Other Parts Discussed in Thread: PCM3070
Hello
Thank you for your support.
My customer is developing their Audio product ( Pre-Pro) for 2015 2Q model using PCM3070 miniDSP.
Anyway, they are in trouble with Build Error ( I had also confrimed in my PC)...
Where
: use Loudness with sample .pfw fille ( if you accept in offline, I will send that)
:PPS Home Audio: version 5.95 Build1
:Win XP PC
Inquiry:
Would you please givet me advise how to fix this?
I think there are something wrong for usage of Loudness,
I hope your adivse within 3days.
Error message is following...
Best Regards
MemoryType usage: miniDSP_A_coeff: 73, miniDSP_A_data: 160, miniDSP_A_instr: 200,
miniDSP_A_instr_alloc: 212, miniDSP_A_cycles: 200, miniDSP_A_cycles_alloc: 904,miniDSP_D_coeff: 82, miniDSP_D_data: 169, miniDSP_D_instr: 424, miniDSP_D_instr_alloc: 457, miniDSP_D_cycles: 379, miniDSP_D_cycles_alloc: 904
Assemble failed
Error: aic_gen.asm(2063): Address Expected : Volume_1_volout_loudness - must be a Coefficient variable reference or a hex, decimal, or binary integer
Error: aic_gen.asm(2072): Address Expected : Volume_1_volout_loudness - must be a Coefficient variable reference or a hex, decimal, or binary integer
2 errors detected
Assembler was terminated.
Summary: 2 Error(s)
Code generation terminated on base main Rate44
Build failed.
