PCM3070 and TLV320AIC3254
Other Parts Discussed in Thread: PCM3070, TLV320AIC3254
Hi TI experts,
We have a project which is based on rdk-value-sb. We are interested in swapping its PCM3070 by TLV320AIC3254. We found that these two IC are pin-to-pin compatible, miniDSP configuration can also be shared. Is it possible to swap the PCM3070 to TLV320AIC3254 with minimum firmware change. We like to align the parts in different project. Also the local distributor said TLV320AIC3254 has larger volume and better quote.
Can you share your comments?
Peng
