Power Output of TPA6211A1 as Load Drops Below 3ohm?
Other Parts Discussed in Thread: TPA6211A1
How does the maximum power output of the TPA6211A1 change as the load drops below 3ohm? The data sheet lists a maximum power output of 3.1W at 3ohm, but it does not show data below 3ohm.
I'm trying to determine the maximum output power of the amplifier if a speaker shorted (i.e. the resistance drops to ~0.5ohm). I know that the amplifier has built-in shorting protection, but I want to make sure that my speaker wire won't melt due to high current.
