can i send the signal by I2S into matlab on my PC ,after doing my algorithm,then send the control singal into miniDSP by I2S,then output by HPL or HPR,is it possible??
Hi Shi,
In order to fully answering your question, can you provide more information or a block diagram of the signal path you want to follow?.
You can send the processed signal into the MiniDSP of the AIC3254 via I2S and use PurePath studio to change the device settings. Then you can configure the device to stream the audio through HPL and HPR.
Thanks and Best Regards,
-Diego Meléndez López
Audio Applications Engineer
