Hello Friends!
After many days reading through your helpful posts and wonderfulinformation within the TI.com site, I'm in need of some clarification and maybe a bit of help, if willing.
I'm a professional live sound audio engineer and musician by day and very novice electrical engineer/ designer by night…so be easy on me!
I've been working on a solution to provide a cost effective, simple, short range (1m-15m), low latency, wireless audio for small to large stages within my live audio world. This is an attempt to reduce cabling and cabling runs, patching issues, set-up/out complexity and time, etc..
The idea would be to have a small, rechargeable battery powered RF transceiver that attaches directly to a microphone or output. This plug-on device would contain a fixed preamp, transceiver, input jack/female xlr, and battery.
This would sync to a master module which would simply be plugged into an audio sub snake or main snake head.
From what I've been able to research about the PurePath CC85xx products, is it safe to say the following is true?
1) Only 4 units can operate within the same space. Although I've seen some other techniques with "user RF channels" and also multi-channel CC85xx. http://e2e.ti.com/support/wireless_connectivity/f/382/t/324640
2) 10.6 msec latency is the absolute lowest latency possible with legitimate audio quality (using SLAC)
3) A circuit like the reference design running in autonomous mode yet without the range extender give me these limitations?
4) Am I on the wrong path?
Thank you all in advance for any help you can bring to the table. Very excited to keep learning!
