I am looking for a surface mount replacement for the Xicon 42TM016-R.
Does TI have something that could be used in it's place?
EJ
EJ
Hi EJ,
Unfortunately we don't have a similar part, can you share more details of your application so we may be able to point you to one of our devices as a solution?.
Thanks and Best Regards,
-Diego Meléndez López
Audio Applications Engineer
Hi Diego,
I work with EJ. We are looking for a surface mount equivalent to the Xicon 42TM016-R. We are using to go from the differential output of the Taiwan Semi TS34118 to single ended camera input. It’s a 1:1 Audio transformer. I don’t need the very large voltage isolation rating. Any parts you can suggest?
Madhu
