Other Parts Discussed in Thread: MSP430F5528, MSP430F5510
Hey
I am developing an Audio codec using the TIs AIC3254 chip.
For the interface, they have suggested a USB streaming controller which they no longer support and other alternatives are a full blown Audio DSP chips, which does not makes sense since I am developing with an Audio codec already. I just need an interface to have it programmed with USB.
http://www.ti.com/lit/ug/slau295a/slau295a.pdf
So what kind of a microcontroller could be suitable, that is its specs, like memory, RAM, etc. I just require only a microcontroller with I2S support.
Since, the only program I want to run are bass extension and equalization, which the PurePath already provides, so for that what could be the minimum specs that would help to make it run efficiently. Wouldn't mind using an external Serial EEPROM, if microcontroller is costly for that memory.
This ROM is what is used in the reference schem - http://www.microchip.com/wwwproducts/Devices.aspx?product=24AA256
Thanks.
Thanks.
