tiaudioi2c driver for tpa6140
I have the same problem with the TPA6140 like described in the Forum. But in meantime, the TPA2016 link must have changed, cause there the good driver is not available. I tried several other locations (0728drivers.zip and TPA2028) but all drivers don t work.
Where can I find a Windows7 32 Bit driver for the TPA6140 Evaluation Module ?
  • Hi Uwe,
    Have you downloaded the latest software from the device product folder in ti.com?, Also, can you please check if you have the latest NI-VISA drivers?.
      -Diego Meléndez López
       Audio Applications Engineer
  • Hello Diego,
    Thanks a lot for your help. I am one step ahead. I could install it on a different Windows7 64 Bit PC. There it works.
    The problem with the 32 Bit Windows7 Laptop is, that I cannot uninstall the NI VISA driver, and that there is a newer version of the NI Visa drivers, which doesn t work with the TPA6140. Any idea how to fix this ?
    Uwe Renschler
