Other Parts Discussed in Thread: TPA6100A2, TPA6133A2, TPA6138A2
Hello
My customer has just started ES of their headphone using TPA6100A2, and they
intend to use /SHUTDOWN as a mute control.
*Customer let /SHUTDOWN held low before ~ 10ms VDD goes low.
*Schematic is just same as data sheet page 1 ,Co=100uF Ci=1uF.
However, audio signal is muted after ~20ms of /SHUTDOWN goes low, and there are pop noise.
I'd attached the waveform.
Q1
Do you think /SHUTDOWN can be used as a audio mute?
If yes, do you have a recommended power off sequence of /SHUTDOWN and VDD?
Q2
As per customer's result, mute of audio signal by /SHUTDOWN delays ~ 20ms .
Is this inherent issue of TPA6100A2 ?
Q3
Do you have any recommended device in place of TPA6100A2?
I'm sorry that I don't have EVM and I did not tested myself....
II would like to have your advise
Best Regards
