Hello all,
I'm using the pcm3070 in a evaluation board evmc5517. Using the code examples, I made work the classic function on getting the input, ADC, data to host via I2S bus, then, sent it back with I2S to Codec to DAC.
I wanted to modify the registers and the configurations of the PCM3070, so data is shortcutted, so from in ->adc->dac-> output, but I couldn't succed. All data are transfered throught i2s.
After reading the documentation, application note, I couldn't find the proper register that allow me to have the main processing chain inside the pcm3070. Could you help me? By the way, unsuccesfully tried PurePath, with no better results.
Thank you in advance
ip
