I'm working with a customer who has encountered several instances where the TPA2005D1 amplifier entered shutdown mode for an undetermined reason.
Symptoms and observations:
1) Once shutdown begins, it persists until the power supply voltage is removed and then restored
2) While shutdown is underway, the outputs are static
3) The SHUTDOWN signal is strapped to the non-shutdown state
4) The package being used is the 8-pin MSOP
5) An examination of one PCB exhibiting the problem revealed proper soldering of the pad on the bottom of the package
Question #1: Are there any known mechanisms other than thermal overload and improper loads that will produce the shutdown state?
Question #2: Is it normal for the shutdown state to persist until the supply voltage is removed/restored? (Alternately, does the shutdown state behave the same way for thermal vs. improper load shutdowns?)
gerald
