Audio codec tlv320aic3268
hello
i am trying to change the Fs to 8KHz and using the script 1.0 as an example
# Clock configuration
# MCLK = 12.288 MHz, BCLK = 3.072 MHz, WCLK = 48 kHz (slave)
w 30 00 00 # Select Page 0
w 30 04 00 # Set DAC_CLKIN as MCLK -- default not mandatory to program
w 30 0b 81 # NDAC = 1
w 30 0c 82 # MDAC = 2
w 30 0d 00 # Program the OSR of DAC to 128 to get
w 30 0e 80 # DAC_FS = DAC_MOD_CLK / DOSR = 6.144MHz / 128 = 48kHz
could use some help
thanks
  • Hi Kim,
    In the script 1.0, the Fs is determined by the MCLK and the NDAC, MDAC and DOSR dividers. Configuring MDAC = 12, the Fs will be 8kHz.
    w 30 0c 8c # MDAC = 12
    For any other clock configuration, you may check the 8.3.4 Clock Generation and PLL Section in TLV320AIC3268 datasheet.
    I hope this helps you. If you still have questions, please let me know.
    Luis Fernando Rodríguez S.
