TLV320AIC3254 Shutdown Cross Talk issue
Other Parts Discussed in Thread: TLV320AIC3254
Hi everybody,
Currently I am using the TLV320AIC3254 with single ended inputs on IN1_L, and IN1_R.
When the device is powered-down, there is a serious crostalk (bleed through the device) to the HPL, HPR outputs.
Hereby attached the schematic diagram. Please help/advise.
Kind regards,
AlainTLV320AIC3254.pdf
8244.TLV320AIC3254.pdf
  • Hi, Alain,
    Welcome to E2E and thank you for your interest in our products.
    The crosstalk is a normal behavior of the codec. The analog bypass to headphone amplifier works properly only if the TLV320AIC3254 is turned on. So, to avoid the crosstalk, I suggest to use an input signal only if the codec is turned on.
    I hope this helps you. If you still have questions, please let me know.
    Luis Fernando Rodríguez S.
  • Hi Luis,
    Thank you for the quick reply!
    Is there a "one or more" compatible TLV320 device that does not suffer from this shutdown crosstalk issue ?
    Otherwise I'll need to place a relay ( coil powered by 3.3V) between the HPL,HPR signals and the headphone connector.
    Any other suggestion/workaround highly appreciated! (I need to respin the PCB anyway...)
    Kind regards,
    Alain
  • Hi Alain,
    All the TLV320 devices must respect the power supply voltage ranges for the correct behavior. The power supplies must reach a minimum value to work properly, so probably all the TLV320 devices will suffer this shutdown crosstalk issue when they are powered down.
    Regarding your PCB design, I suggest to take a look of TLV320AIC3254EVM-K User's Guide. In appendix section, you may find a suggested design and components for the TLV320AIC3254 codec. Additionally, I recommend to take a look of 12. Power Supply Recommendations Section  and 13. Layout Sections of TLV320AIC3254 datasheet
