Other Parts Discussed in Thread: LM1972
Hi all,
I'm about to design a preamplifier section with an audio op. amp. (OPA2322S)
The amplifier feedback will be controlled with a digital potentiometer, I want to implement also the mute feature, could I take advantage of the op. amp. shutdown?
In shutdown mode the op. amp output will act as an open circuit, so the only way for the input signal from the input to the output is the feedback net, correct? There are other methods to achieve the mute feature without using a LM1972?
Thanks in advance
