Could you please tell us the maximum attack and decay time constants which we can set at the 48kHz processing ?
In addition, please tell us the calculation example(each register values, etc).
Kato
Kato
Hi Kato-San,
You can find the maximum attack and release time for the TAS5727 by using the GUI DRC tool. For this you need to set Rate Sliders to ON in properties window of the DRC band block.
Then you can see the range of values of each time constant with the equivalent hex value that should be written into the corresponding register by double clicking in the DRC block.
-Diego Meléndez López
Audio Applications Engineer
