We are working on a new design for which we found TLV320AIC3254 suitable.
However, we are having some difficulty optimizing the AGC. We have tried to tweak the various parameters, but the automatic gain control keeps amplifying too much noise (it's being used in a fairly noisy environment). Changing the noise threshold does not give us the desired result.
It's a mono microphone setup (record path) and we are looking for the following signal processing: Provide linear PGA gain (no noise gate) from 0 up to a defined target level. Input signals above the target levels will be attenuated as current agc. In other words, tweak the AGC into an advanced output limiter. Is it possible to implement with the chosen chipset?
BR,
Eggz
