Since the PCM2903C includes the ADC and DAC, so it should be support analog in to analog out at the same time. Does the PCM2903C support the mic-in to line out at the same time?
Gary Chen
Hi Gary, PCM2903C support simultaneous Analog In and Analog Out. It doesn't have mic-in. Analog Out and Analog In both have "Line" voltage levels. It is described in datasheet. Vpp for Out and In is 0.6 * VCCC which is about 1.98V.
Pavel
Does the PCM2912A whether support android driver? Or has other USB audio code solution can support android driver? Appreciated your recommends. Thaks.
Gary
