I would like to ask you basic questions about TAS5414 as below.
Q1) S/N performance
Is there happened S/N performance difference(worse) in following cases?
- In case of 2 outputs are used and other 2 ch are open (unused)
- In case of PBTL usecase (2ch outputs), only 1 ch is used and other ch is open (unused)
Q2) About "Open" ch
Is there anything problem happend in case the unsued outputs are open ("not to connected to Speaker")?
"Open" means 2 way - first case is just open " output pin", 2nd case is configured "pin + LC filter" with no speaker.
If there seems not to be good to open outputs, could you tell me anything recommend reference circuits?
Thank you in advance.
