Hi ,
One of my customer has a question about overshoot/undershoot on PCM1681.
I could't find these parameters on datasheet.
Please help to provide over/under shoot parameters of PCM1681.
Taka
Hi ,
Taka
Hi Justin,
Thank you for your kind support.
My customer has confirmed the following input waveform on their board.
- Undershoot is about -0.6 volts
- The duration is 2ns.
From "7.1 Absolute Maximum Ratings" of PCM1681 datasheet, the minimum value of input voltage is -0.3 volts.
Therefore, it exceeds the maximum rating. Is that a problem for PCM1681 device?
Taka
Hi Justin-san,
Fistlly, I apologise for the delay in replying to you.
Also, my customer are no longer thes problem of over/undershoot by reviewing their circuit.
Currently, it is fit within the "Absolute Maximum Ratings" of datasheet.
Therefor, I will close this quetion.
Taka
