Hello All,
I have a TLV320AIC3254EVM-U, and I am having trouble getting the double buffer to work. I have it enabled under the DAC section of the framework. Even with just trying to change the volume, it will not work in real time. If I disconnect and re-download the code, does the volume change. If I use the GUI software for the EVM board, I dont have a problem. I can change stuff in real time.
I know it has to be something I am doing, because it worked before I had some problems (https://e2e.ti.com/support/data_converters/audio_converters/f/64/t/449246) that were fixed. And before I switched to Windows 10. I went back to Windows 7, thinking that was the problem.
Does anyone have some ideas I can try to be able to update values in real time?
Anthony
