Hi, I have designed a board using the PCM2706 based on the schematic from page 29 of the datasheet.
The idea is to be able to connect an smartphone running Android in order to charge it and at the same time to play music using an Android app that plays music through USB.
So far I a able to charge the phone (nothing too exciting), but the app doesn't recognize anything connected to the USB.
Is PCM2706 the right device for this application? If so, what should be the right setting for: HOST, FUNC0:3, HID0:2, FSEL, TEST, DT, PSEL and DOUT? I have try a lot of settings but nothing.
Also, what should be the right voltages for Vbus and Vdd?
Thanks in advance for any help you could provide.
