TDM8 to AES transmitter using SRC
Other Parts Discussed in Thread: SRC4190
We need to convert from a TDM-8 bus to 4 x AES Outputs, Can we use four  SRC 4190 connected to four DIT 4192?  We found information that SRC4190 works creating a TDM output... but can we use it  with a TDM input?   If not what IC do you recommend us?
  • Hi Oscar,
    This does not look like it will work. Even if the part could take in the TDM and focus on two channels, its outputting it in TDM, you would be right back where you started. It looks like we do not have a part that can solve this issue. Either the source of the TDM would have to switch to I2S with multiple data lines, or any possible solution we would come up with would take a wasteful amount of parts.
    Justin
