I'm trying to understand the the data sheet of the TPA3251Dx reset pin correctly.
If I understood the data sheet correctly, then there is no certain need to pull the reset pin down for the IC to work properly. Please correct me if I am wrong.
/RESET is asserted high for normal operation. We do recommend keeping /RESET low for >200ms after power up to prevent pop/click noise. Also /RESET pin needs to be toggled low to clear latching errors as on page 20 of the datasheet.
