TLV320AIC3262 initial code for Ambarella
Other Parts Discussed in Thread: TLV320AIC3262
Could you help provide TLV320AIC3262 initial code for Ambarella platform?
thanks!
  • Hi, Ray,
    Please take a look at the following examples. The record mode is in the first script and the playback mode is in the second script.
    # ADC Stereo Record - High Performance
    # SE input signal from IN2L/IN2R
    # AVDDx_18, HVDD_18, CPVDD_18 = 1.8V; IOVDD, AVDD3_33, RECVDD_33 = 3.3V; SLVDD, SRVDD, SPK_V = 5V, DVdd = 1.8V
    # MCLK = 12.288, Fs = 48kHz
    # PLL Disabled, AOSR = 128, PTM_R1
    # CM = 0.9V
    # Primary I2S Interface used with WCLK & BCLK as inputs to the device
    # Software Reset
    w 30 00 00        # Initialize to Page 0
    w 30 7f 00        # Initialize to Book 0
    w 30 01 01        # Initialize the device through software reset
    d 1               # Delay 1 millisecond
    # Power and Analog Configuration
    w 30 00 01        # Select Page 1
    w 30 01 00        # Disable weak AVDD to DVDD connection and make analog supplies available
    w 30 7a 01        # REF charging time = 40ms
    w 30 79 33        # Set the quick charge of input coupling cap for analog inputs
    # Clock configuration
    # MCLK = 12.288 MHz, BCLK = 3.072 MHz, WCLK = 48 kHz (slave)
    w 30 00 00        # Select Page 0
    w 30 04 00        # Set ADC_CLKIN as MCLK1 -- default not mandatory to program
    w 30 12 81        # Power Up NADC, NADC = 1
    w 30 13 82        # Power Up MADC, MADC = 2
    w 30 14 80        # Program the OSR of ADC to 128, ADC_FS = ADC_MOD_CLK / AOSR = 6.144MHz / 128 = 48kHz
    # Audio Serial Interface Routing Configuration - Audio Serial Interface #1
    # ASI #1 recording
    w 30 00 04        # Select Page 4
    w 30 01 00        # Audio Serial Interface #1 is set to I2S mode, 16-bit
    w 30 0a 00        # Route ASI#1 WCLK and BCLK to WCLK1 pin and BCLK1 pin
    # Signal Processing Settings
    w 30 3d 01        # Set the ADC PRB Mode to PRB_R1
    # ADC Input Channel Configuration --- IN2L / IN2R
    w 30 08 00        # Set the input common mode to 0.9V
    w 30 34 20        # Route IN2L and CM1 to LEFT ADCPGA with 20K input impedance
    w 30 36 80
    w 30 37 20        # Route IN2R and CM1 to RIGHT ADCPGA with 20K input impedance
    w 30 39 80
    w 30 3B 00        # Left Channel Analog ADC PGA = 0 dB
    w 30 3C 00        # Right Channel Analog ADC PGA = 0 dB
    w 30 3D 00        # ADC Analog programmed for PTM_R4
    w 30 51 C0        # Power-up ADC Channel
    w 30 52 00        # Unmute ADC channel and Fine Gain = 0dB
    # Headphone playback
    # AVdd = 1.8V, DVdd = 1.8V, MCLK = 12.288MHz
    # PLL Disabled, DOSR = 128, PRB_P1
    # Primary I2S interface used with WCLK & BCLK as inputs to the device
    # Software Reset
    w 30 00 00
    w 30 7F 00
    w 30 01 01
    # select MCLK for CODEC clock input, bypass PLL
    w 30 04 00
    # NDAC = 1, MDAC = 2
    w 30 0B 81
    w 30 0C 82
    # DOSR = 128
    w 30 0D 00
    w 30 0E 80
    # Initialize the Codec
    # select page 1
    w 30 00 01
    # Disable weak connection between AVDD and DVDD
    w 30 01 00
    # set the REF charging time to 40 ms
    w 30 7A 01
    # ASI #1 configuration
    # select page 4
    w 30 00 04
    # set ASI#1 16 bits, I2S mode
    w 30 01 00
    w 30 0A 00
    # Signal processing
    # select page 0
    w 30 00 00
    # set DAC PRB mode to PRB_P1
    w 30 3C 01
    # DAC configuration
    # select page 1
    w 30 00 01
    # Set DAC PTM mode to PTM_P3
    w 30 03 00
    w 30 04 00
    # Route LDAC to HPL and route RDAC to HPR, don't power up HP driver yet
    w 30 1B 30
    # select page 0
    w 30 00 00
    # power up LDAC and RDAC
    w 30 3F C0
    # select page 0
    w 30 00 00
    w 30 3F C0
    # select page 1
    w 30 00 01
    # set Headphone in Ground-centered Mode, HPL is still muted
    w 30 1F B9
    # HPR has the same gain as HPL, HPR is still muted
    w 30 20 B9
    # Charge pump runs of Oscillator clock with divider = 4
    w 30 21 28
    # headphone output offset correction (default setting)
    w 30 22 3E
    # Charge pump to power up on the headphone power up in Ground-centered Mode
    w 30 23 30
    # unmute HPL driver, set gain = 0 dB
    w 30 1F 80
    # unmute HPR driver, set gain = 0 dB
    w 30 20 80
    # select page 0
    w 30 00 00
    # Unmute LDAC and RDAC digital volume
    w 30 40 40
    # select page 1
    w 30 00 01
    # reduce HP power to 25 percent
    w 30 09 70
    # power up HPL/HPR
    w 30 1B 33
    # select page 1
    w 30 00 01
    # increase HP power to 100 percent
    w 30 09 10
    Please let me know if you have more questions or comments about the examples.
    Luis Fernando Rodríguez S.
