Does TI have an OPEN LOOP Class-D amplifier on its road-map?
Other Parts Discussed in Thread: LM1875, LM3886, TPA3002D2, TPA3004D2, TPA3124D2
I am still stuck with the LM3886, the LM1875 and the TDA7293/4. They are simple to build, cheap and more importantly they allow me to use them as current drivers.
Once you have heard the current drivers, there is no going back to the voltage amplifier topology. The difference is just too sweet.
I would love to try it out on Class-D but most use BTL output, so will need an expensive Diff-amp to sense load current (while minding the common mode voltage) but then these amps do not readily allow me to close the loop.
TI just needs to give us something in Class-D that will allow us all the variations/ topologies that the Class-AB amp allowed. I am looking at something similar to the solution that IRF has around the IRS2092 but am wondering if TI has anything in their roadmap that is simpler.
I look forward to some suggestions on this.
Ravindra.
