Other Parts Discussed in Thread: PCM1863
Hi Sir
1. if using external xtal, can PCM186x support I2S master mode and up to 192Khz sample rate?
2. please help to select external xtal frequency in support 192Khz or 96Khz.
3. can SCKO configured as MCLK output and fed to DAC.
4. in power down mode, can it senses analog input signal and trigger INT pin?
5. is there any different with power consumption between 192Khz and 96Khz in sleep(Energysense) mode?
Bogey
