Hi Team,
Could you let us know how to tune the Q value for the Bass/Treble Shelf filter?
e2e.ti.com/.../Filter-Equations.pdf
Scott
Hi Team,
Scott
Hi, Scott,
As I mentioned before, the formula used for the calculation of the Treble/Bass Shelf Filters is indicated in the pdf you are attaching, and does not allow the use of Q as input parameter. The formula used by the GUI considers a Q factor of 1/sqrt(2), equivalent to 0.707 as this is the optimized Q for this kind of digital filters.
If the Q factor is required to change, I think the only solution might be to calculate the coefficients externally and load them to the GUI. It would be complicated to add a Q tuning function to the GUI as the Shelf filters implemented in our GUIs are optimized to have the better response.
-Diego Meléndez López
Audio Applications Engineer
Hi, Scott,
Thanks for clarifying your question. From the PDF file, it would be complicated to tune Q factor as this parameter is set to a constant value, so the formulas you are seeing, are already optimized for the filter type. I think we have a file used to calculate the BQ coefficients, I will look for it and perform some tests to see if it works as expected. I will contact you as soon as I get any update.
