Other Parts Discussed in Thread: TPA2028D1
We faced with problem of audio amplifier, and realy need help and feedback related the case.
ON: TPA2028D1
You can repeat this bug follow these steps exactly as written:
Set 3 dB volume and play audio
Set 30 dB volume and play audio
The second audio volume with AGC off will be like 3 dB. Next time you play it will sound like 30 dB.
This is problem. We must play audio with different gain. And when we start playing second (high fixed gain) audio after the first one (low fixed gain) we unable to get appropriate sound level from amplifier.
Register settings are:
0xC3
0x01 - Attack time
0x01 - Release time
0x01 - Hold time
0x03 - Fixed gain 3 dB, Fixed gain 30 dB - 0x1E
0x60 - Noise gate threshold
0xC0 - Compression ratio 1:1
Problem was mentioned in e2e community.
http://e2e.ti.com/support/amplifiers/audio_amplifiers/f/6/p/253229/891982
https://e2e.ti.com/support/amplifiers/audio_amplifiers/f/6/t/438676
Do you have solution for it?
Best Regards
Martin
