I've made the following app:
I want to operate at 16 kHz. Therefore I added the command file as "execute on reset" in my project as below. I now encounter the following problems:
1. At 16 kHz this is not working (I hear loud noise), it operates at 44.1 kHz. At least I can hear some audio data, then. At 8 kHz the device is operating, too. Is so, that the NR does not operate at this frequency?
2. The microphone input is not working - I only have the Line-input.
Any help is welcome.
Micky
My I2C-Command File is (as provided by Texas)-
# Power Down Sequence
# Select Page 1
w 30 00 01
# Power Down HP/LO Amps
w 30 09 00
# Select Page 1
w 30 00 00
# Power Down DACs
w 30 3F 14
w 30 40 0C
# Power Down ADCs
w 30 51 00
# Configure Power Supplies
# Select Page 1
w 30 00 01
# Power up AVDD LDO
w 30 02 A9
# Disable weak AVDD in presence of external
# AVDD supply
w 30 01 08
# Enable Master Analog Power Control
# Power up AVDD LDO
w 30 02 A1
# Set the input power-up time to 3.1ms (for ADC)
w 30 47 32
# Set the REF charging time to 40ms
w 30 7b 01
# Configure ADC Channel
# Select Page 1
w 30 00 01
# Route IN2L to LEFT_P with 10K input impedance
w 30 34 10
# Route CM1L to LEFT_M with 10K input impedance
w 30 36 40
# Route IN2R to RIGHT_P with 10K input impedance
w 30 37 10
# Route CM1R to RIGHT_M with 10K input impedance
w 30 39 40
# Unmute Left MICPGA, Gain selection of 0dB to
# make channel gain 0dB, since 10K input
# impedance is used single ended
w 30 3b 00
# Unmute Right MICPGA, Gain selection of 0dB to
w 30 3c 00
# Select Page 0
w 30 00 00
# Power up LADC/RADC
w 30 51 c0
# Unmute LADC/RADC
w 30 52 00
# Playback Setup
# Select Page 1
w 30 00 01
# De-pop: 16 time constants, 6k resistance
w 30 14 35
# Route LDAC/RDAC to HPL/HPR
w 30 0c 08 08
# Route LDAC/RDAC to LOL/LOR
w 30 0e 08 08
# Power up HPL/HPR and LOL/LOR drivers
w 30 09 3C
# Unmute HPL/HPR driver, 0dB Gain
w 30 10 00 00
# Unmute LOL/LOR driver, 0dB Gain
w 30 12 00 00
# Select Page 0
w 30 00 00
# DAC => 0dB
w 30 41 00 00
# Power up LDAC/RDAC
w 30 3f d6
# Unmute LDAC/RDAC
w 30 40 00
