I've two question regarding PCM1808:
1) what is the cut-off value for the integrated analog antialias LPF?
2) Regarding the control Pins in section 8.2.2.1 (pg 20 in datasheet), if select “H”, I would need to pull up by 10kohm to VDD. If select “L”, merely directly short to GND (no need 10k pull down resistor to GND). Is my understanding correct?
Could you advise?
