I am trying to build a class d amplifier using TPA3106D1. I have used the same pcb layout provided with evaluation board with same component values. I have 2 problems
1. I get clear audio output when my input signal amplitude is low. At higher input levels noise is predominant at output.
2. How should I varify I am getting 30W output as stated in the datasheet? As conventional method of applying sine wave at input and measuring output on CRO can not be applied, how should I measure power output?
