Other Parts Discussed in Thread: TAS5624, TPA3251, TAS5624ADDVEVM
I'm looking at the TAS5624 and TAS5261 amplifiers --- I was hoping that they would accept a PCM stream through an I²S standard connection, but as I understand from the datasheet, this is not the case.
Is this PWM input that these amplifiers expect some standard format that I could expect DSP chips to produce? For the project I have in mind right now (hobby/DIY level), I'm planning to get audio from a PC through USB (using the PCM2707), output PCM through I²S to an ADAU1701 (from the Analog Devices SigmaDSP series) for processing. Should I expect that this DSProcessor will be able to output PWM data that the TI amplifiers accept?
If not, I guess what I would be looking for is a PCM-to-PWM converter --- I could not find any through the products section on TI's web site.
Any tips/pointers will be appreciated.
Carlos
