TLV320DAC3101: How to config TLV320DAC3101 sample rate?
Part Number: TLV320DAC3101
      How to config TLV320DAC3101 sample rate to 8Khz,11.025khz,16Khz,22.05khz,24khz,48khz.
     I didn't get the config information clearly in datahseet,Could you give me some advice and sample,Thank you!
  • Hi, Feng,
    The sample rate configuration depends of the PLL_CLKIN being used. Table 5-28 PLL Example Configurations of datasheet shows several examples to configure the sampling rate at 44.1KHz and 48KHz with a different PLL_CLKIN:
    www.ti.com/.../tlv320dac3101.pdf
    Could you provide your PLL_CLKIN? I can provide several examples for 8Khz, 11.025khz, 16Khz, 22.05khz, 24khz and 48khz.
    Luis Fernando Rodríguez S.
