TAS5630B: pps
Part Number: TAS5630B
Hello. I am working on an amp design, and would appreciate PurePath Studio. I have requested it from you request form and was told that i was not able to download it. We are a small design company, and it would be nice to be able to use it as a design tool.
Thank you for your time.
  • Hi Michael,
    Make sure that you fill out the request form in full. if you don't have production dates or numbers at this point just put "N/A" or "TBD".  That would be the only reason I could imagine for it denying you access.
    you could also check www.ti.com/mysecuresoftware just to see if there is an off chance you already have access.
    let me know if you continue to have problems.
    -Steve
  • Hi Michael,
    Were you able to access the PPS download?
    best regards,
    -Steve
  • On 2017-02-24 09:09, Steve-Wilson wrote:
    > #outlook a {{padding:0;}} body{{width:100% !important;
    > -webkit-text-size-adjust:100%; -ms-text-size-adjust:100%; margin:0;
    > padding:0; background: #ffffff;}} .ExternalClass {{width:100%;}}
    > .ExternalClass, .ExternalClass p, .ExternalClass span, .ExternalClass
    > font, .ExternalClass td, .ExternalClass div {{line-height: 100%;}}
    > #backgroundTable {{margin:0; padding:0; width:100% !important;
    > line-height: 100% !important;}} img {{outline:none;
    > text-decoration:none; -ms-interpolation-mode: bicubic; max-width:
    > 100%;}} p {{margin: 1em 0;}} a {{border:none;color: #0087c3
    > !important; text-decoration: none;}} a:active {{ color: #0087c3
    > !important; }} a:visited {{ color: #0087c3 !important; }} table td
    > {{border-collapse: collapse;}} table {{ border-collapse:collapse;
    > mso-table-lspace:0pt; mso-table-rspace:0pt; }}
    > A Message from the TI E2E(tm) Community
    > RE: TAS5630B: pps [1]
    > Steve-Wilson [2]
    > Hi Michael,
    > best regards,
    > -Steve
    > Did this answer your question?
    > Verify it as the answer [3] or Reject it as the answer [4]
    > View online [1]
    > You received this notification because you subscribed to the forum.
    > To unsubscribe from only this thread, go here [5].
    > Flag [6] this post as spam/abuse.
    > Links:
    > [1]
    > e2e.ti.com/.../2117069
    > [2] e2e.ti.com/.../4798028
    > [3]
    > e2e.ti.com/.../verifyanswer
    > [4]
    > e2e.ti.com/.../rejectanswer
    > [5]
    > e2e.ti.com/.../mute
    > [6]
    Yes thank you so much
