TAS2505: About Tas2505 broadcast sound quality problem
Part Number: TAS2505
dear:
I use the Tas2505 driver SPK, audio playback of sound quality problems are not soft and delicate, can you adjust those registers to improve?thanks!
  • Hi David,
    Are you using digital or analog input? Could you share your register settings and your application/system specifications?
    A distorted signal at the output could be caused by a wrong configuration on the clock dividers for the sampling frequency.
    -Ivan Salazar
    Texas Instruments
