Part Number: TAS5756M
with PurePath_Console2_2.1_r35934, TAS5756M PBTL mode, hybrid flow 4, dump the .h file of base configuration. settings as below of ppc2.
1. hybrid flow 4
2. dump .h file
copy the cfg_registers[] generated .h file to mcu code, and add the exit standby code at the end of cfg_registers[], download to mcu and run, but SPK+/- output voltage is same as PVDD voltage, and check the signal by oscilloscope, no pwm waveform output on SPK+/-.
check the timing of i2c, it is ok.
whether the base configuration file need use the .cfg output?
