Please find the attached pdf of schematic of TPA3128D2 IC with microcontroller and GSM, please check the connections.
Here we are using:
- Quicktel GSM module
- 12VDC SMPS power supply
We have following queries at the time of designing:
- Where we connect MODSEL Pin.
- As per datasheet, This IC provides 2x30W Audio output, So what is the current require by the IC?
- Is it necessary to connect Heat sink for the device TPA3128D2???
- Regards
- Atul Bhakay
- Audio_TPA3128D2.pdf
