TLV320AIC3263EVM-U: Using EVM TAS1020b for quick bringup on my board
Part Number: TLV320AIC3263EVM-U
Hi TI,
I'd like to wire the output of the TAS1020b to my AIC3263 to enable me to use the GDE and the CodecControl software suite on my spin of the board.  How would I need to connect these devices for this to work?
Thanks in advance,
Aaron
  • Hi, Aaron,
    You would need to connect the I2C lines from the EVM to you board. You may use the SCL/SSZ and SDA/MOSI test points. In that way you will be able to configure the EVM and your board at same time. Additionally, you may also route the I2S clocks to your board in case you require to send audio data.
    Luis Fernando Rodríguez S.
