PCM2704C: Vout coupling capcitor
Guru 16770 points
Part Number: PCM2704C
Other Parts Discussed in Thread: TAS2521,
Hi
We are about to evaluate audio system using PCM2707C and TAS2521 as follows.
According to the datasheet, PCM2704C requires series 100-uF electrolytic capacitors at the Vout line.
1.  Are there any reason why electrolytic capacitor is used?
Is it OK to use ceramic one?
2. Are there redundant component in the upper figure?
If so, could you please point it out?
BestRegards
