Hi All,
I want to use MPIO_C as an input, however the aforementioned port behaves always as an output, even if i try to change the settings by writing to the relevant registers.
I managed to do the same thing with MPIO_B, but with MPIO_C i have problems as the clocks that i feed interfere with the clocks that the MPIO_C (shouldn't) generate.
I set up MPIO_C as an input(aux1) and then i try to route it to the main port but with no luck.
Am i missing a setting or something related?
Dimitris
